question Zetor 6441 stalls
flexxit22
Texas, USA
Bill
Zetor 6441
I have a Zetor 6441, we had a guy out to cut down 2 large dead oaks. He used the tractor to move large branches to a burn pile. We had to add some hydraulic fluid to it after a few hours. Now it starts and runs it will move forward then just stops ( engine still running). Anyone experienced this?
Hello and welcome Bill !
I would check the clutch first and then the power shift. It is possible that the load clutch is leaking and cannot build up enough pressure or that the plates are worn.
But I would need more details about your machine (year and month, model name, features).
I looked at the ID plate inside the cab all it says is 6441 and serial number not sure if the year. I know the shroud says Proxima
Its only the model name "Zetor 6441".
Not the ID and truely not the production year of. ;)
Ok with 2007 I can work with... (y)
