ZETOR 6745 WILL NOT START JUST BLOWS WHITE SMOKE.
ivore
Ivor Evans
I had to remove the injector pump on my 6745 as the starter button was seized. Stripped it down and freed it up with a good clean. Obviously I turned the pump over many times. On putting it back on I just lined up the cogs as per the workshop manual . I have cleaned the water out of the fuel filters. I have bled the system multiple times. The motor of the tractor has not been turned over whilst the injector pump has been off.
It will not start just blows white smoke which I think is just fuel vapor.
Have I got the injector timing out. Or is it something else.
Also is the front compartment of the injector pump just filled with engine oil or fuel and the rear compartment where the governor is situated is that just engine oil. Any help would be appreciated.
