Zetor 7211 oil out breather + torques
j0rd4n
J0RD4N
hi guys
im new to the forum, and just asking to see if any of you could help me.
our zetor 7211 is putting oil out the breather suspected piston rings waiting on a compression tester. and just after if any of yous have another idea.
and what all the torque settings are for the head and main bearing etc.
thanks in advance
hi guys
thanks in advance
have this tractor worked hard recently? if only used in light work piston rings tend to stick in the grooves causing blow by. Take it for a good hard workout making it pull a Heavy load then if its not Cure the problem, it may take a day or two to see improvement. then you can suspect something wrong With engine.
its been doing quiet a bit of heavy work the last while, could it be something to do with the breather? a few people have said that they've put a breather of a newer model on and it stopped it
[quotepost=3]
[/ -- End of Quote --
when engine is started put Your finger on the end of breather pipe and plug it. how much pressure does it let out is it hard to hold it back With Your finger ? if thats the case its something wrong. if its only a little bit then changing of breather from example a 6340 will work fine.
