question Zetor 7245 Loader Capacity?
rockcod
rockcod
I am in Australia and have been researching a lot of tractors since I need to buy one :)
The old Zetors seem to tick a few boxes for me and I'm currently checking out a 7245.
I am intending on fitting a loader to the tractor and am needing to know what sort of capacity this model can handle on the loader assuming I fit a solid full frame loader.
It wont be doing heaps of loader work but want to make sure that this model is suitable for my needs or if I should be looking at a different one.
Cheers,
Dave
Cheers,
Dave
We bought a brand new one back in 1987 with a Quicke 2300 loader we used for several years pushing up silage and feeding cows, it has no bother lifting half ton bags of fertilizer anyway or bales of silage and wouldn't of had any weights behind either, it was replaced by a short lived 7745 and the 7340 with a shuttle
You think it would cope with unloading 800-1000kg feed bags off a trailer from time to time? It's is the axle I'm not sure about, I don't want to bust anything but it would be good if it could lift a tonne but I wont be doing that very often and wont be in a rush.
I saw some specs online that the front and rear axles were both rated to 35.32kN which is 3.6 tonne each but not sure if that would be right? if so they should be ok.
I don't think any tractor loader would be able for a tonne bag. In Ireland fertilizer comes in half ton bags and front loaders are able to lift 1 them at a time but to up to a 1000kg would be very hard on your loader as they are out too far. you would want a forklift on the back. In the fertilizer stores they can lift 2 half ton bags at the same time but they either have a diesel forklift of a telescopic handler (into the last), I saw my brother's tractor lift a 750kg jeep but he could only get it less than a metre off the ground with a weight on the back.
The loader is just out too far for a front loader to lift 1000kg too mush leverage. a forklift or crane on the back or you'll need a wheeled shovel or digger or you'll need to put your feed into smaller bags
Fair enough, most bulk feed etc over here comes in 1 tonne bags and it seems most modern tractors of 75hp with a loader will lift over a tonne, the old zetors seem to be built tough but not sure if any were more prone to front axle issues that others. I wouldn't want to go much bigger so if the 7745 or 8145 are not much stronger in the front i'd rather stay on the smaller side.
If you were to lift a tonne bag with a loader you would defiantly need a counter weight on the back but your front tyres would not be wide enough to take the weight, and you would not want to lift too high while your moving, the tyres on a 7245 are only 12x24 but the ones on like a telehandler are 540x70x24 and would be able for the weight
Yes, would only be to get it off the trailer and in shed so not high and not far.
Not fussed if it doesn't do it easily, just don't want to break anything expensive:)
Specs on some of the early 90's models in similar size rate the loaders at over a tonne so surely not much would of changed in a couple of years unless some models have wider tyres etc fitted?
Yes for instance our old 8111 had a loader and as soon as you lifted a half tonne bag the 7.50x20 tyres would be pancakes, but with 1100x20 wide tyres at least they could take the weight. I still be cautious about lift 1000kg, even if you can get it up off the trailer when you reverse will lift your back wheels off the ground unless you have a good size weight. If I was in your shoes I would get a forklift attachment for the back, as it takes all the weight and will fit any tractor, as a place near me uses one on a ford major to lift lumps of trees. Or you need a more industrial vehicle, what do they use where you buy the feed to load the bags on the trailer?
They load the bulk bags with a little forklift.
Its not the main thing I want the tractor for so not worried about the full tonne, if I have to put a weight on the back that would be ok if it will do it, I just wanted to make sure these didn't have a weak axle or something that was going to break often and drain my wallet! Sounds like it would be up to the job but if not a fork on the linkage would probably get the job done anyway.
The loader will mainly be for shifting bales, feeders etc, moving a bit of dirt, moving firewood, clean up and such.
i have a 7340 with a quicke loader 3301 it's very strong never gave any bother and the tractor the equivalent of yours i usually give my contractor a hand collecting the bales but last summer i could only lift some of them others no way i would rev the tractor up but it made no change of getting them off the ground
the pump just couldn't lift them
the contractors got a jcb 434 come along and swipe them away i was left picking up ones only on the back
The rest of your jobs would be perfect for a tractor of this size.
It's not the axle that would be a problem I say, it would be the front tyres, whether the pump is strong enough, and if the loader is strong enough to take the weight.
Tractors Ads For Sale in Ireland | DoneDeal - https://www.donedeal.ie/tractors-for-sale/weight-blocks/16825441. The 750kg one
If you stick one of these on the back you would have a bit of ballast anyway
Sounds good, I will more than likely make my own loader unless I can find something suitable that will fit so I can make that plenty strong enough and I can put bigger bore lift cylinders to give me a bit more grunt with lower pressure.
fair play to you if your able to built a front loader yourself , to give you my two cents i have quicke and modern ones are built heavier now but i saw a very industrial type on a zetor it had and independent pump on the pto to increase power called a farmhand loader
Fair play indeed. Some talented engineer we have here. Rossmore must have started the same way.
I'm a boilermaker by trade and the neighbor has a few front end loaders old and new so I''ll measure them up and work something out.
The standard pump on a 7245 is 32l/m I read does that sound about right? is there an additional pump that is commonly used if more flow / pressure is needed or is just running off a standard remote the norm?
Well your still a great engineer to face into building it yourself anyway. What Brandy legs said would be a help having an independent pump on the back with a tank of oil to power the loader and run the PTO would make a difference be like a hedgecuttter, and if you lived near me I could give you them parts.
But if you want to use the back couplings be the norm ok, if you were leaving the loader on her forever, you can take out the centre of the male and female fittings and then you would have no restrictions in the oil flow.
I'll have to check out the hydraulic side of it later on when I have had a look and understand the workings. I have a bit of experience with hydraulics but I'm not to familiar with tractor systems.
Hey Brandy I know that tractor too, you Zetor with the farmhand loader. Was it by any chance a 12145 like yours?
Have a look at these loaders they are farmhand one seriously heavy version, one of those on a suitable tractor and you could a heap of stuff.
Look at the brackets on the second one if your going to build one to lift a tonne you would want the same, brace brackets running at the way back to the stub axles.
That tractor Brandy is talking about was a big Zetor with a loader like this with brace brackets running all the way from the front back to the stub axles and came around the back on the lift with a tank full of oil use for pumping the loader rams as well as counter weight and the pump underneath with a pto shaft. It basically was an industrial tractor loader that you be taking off the loader too often.
There was a Zetor 12045 around here for a good few years , owned by a contracting friend of mine . He fitted a Farmhand F12 loader to it at 1 time , but sold the loader after a couple of years . After another while he fitted a Tanco 1080 loader to it . It had a PTO pump fitted working both. He used the Tanco for stacking silage bales . It was affectionately called "The Chicken Coop". He sold the outfit to a man near Mullinahone Co Tipperary , who didnt keep it very long AFAIK.
i think it was but when i saw it was very dirty and dusty but i do remember the big loader was working on a diary farm
Yes that tanco 1080 loader would have been a real industrial unit too, there's one on DD at the moment on a 12145. They had a boom that could open in the middle so you could take off half the loader if you didn't need it but the back bit was too big of a job to remove. The loader came as standard with a full width bucket and fork but I saw a digger bucket on one.
He bought the 1080 in a Bord Na Mona auction for 500. It came off a Fiat F140 , and a neighbour fitted it to the Zetor in a day. The boom should split in the middle , but this on was welded solid. couldnt be taken off. It came with no attachments.
i saw the one on dd it's black i saw spilt boom ones before in carlow the part that stayed on the tractor was red and the other end was blue
one end kinda fixed into the other with a hook and pin but the boom is a foot wide but that farmhand loader would be the same
I say most tractors with loaders on rarely are taken off, even in summer, they are just worked away all year round maybe just leaving of the grab etc.
The original Quicke loaders were made handy to take off the loader by splitting boom, so front part could left off and the rest stayed on the tractor but in order to strengthen the boom this was phased out with the second series.
So to see Tanco 1080 making a split boom model must have been a bit unorthodox.
Yes, will be doing a frame similar to that, depending on what I can find in the right size to copy I'd probably do level lift arms I think, round bales get stacked 4 high in my hay shed so that would make it a bit easier.
did anyone ever see a quicke hydraulic telescopic loader in real life
they had the ones where you change the pins manually but they also made a hydraulic version
I don't think I ever see one, it be some job ok. Mine is a manually telescopic has 3 setting the most farthest is only suitable for lifting mice
haha i seen 1 in wexford a quicke 2030 out to the last that someone welded another loader on top of to reinforce so to lift more than mice..
were you ever at that machinery place in wexford kehoe or kelly in borris? great places to spend a summers afternoon walking around
oh yes Kelly's & Kehoe's are both great machinery yards but I think Kehoe's had a better selection of junk yards to search through also no shortage of loader choices there too
