Zetor 7745
kocabauto
Ben Kocab
Just put new sleeves and pistons in the ol girl. when putting the last connecting rod cap on, i noticed one of the crank weights is loose. it appears that all i have to do is tighten the two bolts between the weight and the crank. Is this correct? also would anyone have the torque specs for rod, head, main, etc... bolts?
Thanks,
Ben
Yes, I have read from somewhere that if those weights get loose enough, they could fly through the engine block. So tightening is the thing to do...
use loctite on the bolts do it to all even if they are not loose. it has happened on some occasions that wheights has gotten loose and fly through the engine Block.
