Zetor 9540 clutch problems
I know its two years ago but if anyone visits this then I am sure I know the answer. There is an adjusting bolt that the pedal rests on. Slacken this off a bit and the master cylinder takes more fluid in and therefore puts more out and the throw is increased. Took me a while to find it.
If you flick the torque in to low before or whilst changing gear, it always changes smothly for some reason, don't ask me why-
High multiplier increases the drag in the transmission and can make gear changes difficult. Try adjusting the pedal as I sais and this may be better, I could not get mine into gear before I discovered the pedal adjustments
Very valuable advice !!! thanks !
