FAQ Zetor Engine smokes/smokes - troubleshooting and remedy
Germany Joachim
Administrator
Staff member
Wiedemar, Germany
Joachim
My tractor is smoking/smoking unusually - what's going on?
There is no general answer, but the color of the smoke can often indicate the possible cause.
So here in the Zetor Technology Lexicon are a few tips on possible causes...
Smoke/smoke coloring from the exhaust:
Almost colorless, but insufficient engine power:
- air filter clogged​
- and/or incorrectly adjusted or defective injection pump​
and/or defective diesel feed pump​
- and/or clogged fuel line​
- and/or clogged fuel filters or water separators​
- and/or clogged intake pipe in the fuel tank​
and/or air entry into the fuel system (old porous or swollen hoses, cracked pump housing, leaking seal(s) in fuel system)​
White smoke/smoke:
When the engine is cold there is usually condensation and is harmless, but it remains even when the engine is at operating temperature then you should check the following things:​
- cylinder head gasket defective​
and/or cylinder liner defective (rust through, crack, seal defective)​
and/or cylinder head defective (cracked (frost damage or due to overheating))​
- and/or insufficient compression (often seen when/shortly after starting the engine)​
Gray smoke/smoke:
- operating temperature of the engine is too low and therefore incomplete combustion of the diesel-air mixture > warm up during operation​
Blue smoke/smoke:
Tolerable when engine is cold, but disappears when engine is warm. Otherwise the following possible causes:​
- significantly too much engine oil has been filled up, or engine oil is also burned​
- and/or inadequate compression due to stuck piston rings​
and/or oil scraper rings​
and/or worn piston ring grooves​
and/or defective cylinder head gasket​
- and/or worn valve stems and/or valve guides​
- and/or defective injection (incompletely burned diesel)​
- and/or "injection pump ")​
- and/or [URL='http://www.zetor-forum.de/forum/resources/d%C3%BCsenstock-zetor-einspritzd%C3%BCsen-warten-und-erneuern.24/' ]Injection nozzles[/URL] defective (dirty, needle valve stuck)​
and/or injection pump set incorrectly (delivers too much fuel, regulator adjusted)​
- and/or the engine has a lack of air (air filter dirty, turbocharger defective)​
and/or valves defective (burnt, leaking, broken valve spring)​
and/or valves set incorrectly (too much valve clearance)​
- With turbocharger: charge air hose torn or slipped, turbocharger defective.​
- if the engine occurs suddenly, i.e. not consistently when accelerating the engine, and if there is a flame starting system, check it for leaks (shut it off as a test) and replace if necessary​
Smoke from the valve cover breather:
A small amount of smoke/smoke (oil vapor) when the engine is warm is normal here.​
- Stronger smoke and a clear flow of air, especially if it occurs suddenly, indicates a defect in the cylinder head, the compression should be measured. The valves/valve stems should also be checked more closely for wear.​
These are all just rough indications of possible reasons, which should be a first tip for further research into your own Zetor tractor.
If you would like to offer improvements, you are welcome to do so afterwards - I will be happy to add them to the entry. :)
