Zetor pulls out Engine-Oil
patrick1481
Patrick1481
Hello,
I have a problem with my Zetor 5911 again.
After driving my 5911 and turn off the engine, there comes out oil of the engine - pipe.
Can somebody tell me what's wrong then and how I can fix it?
Thanks a lot
Regards Patrick
your piston rings can be worn, causing combustion pressure to pressurise the crankcase.
This is due to back-compression crated.
The Engine Overhaul would be due soon and you are requested to kindly check Engine Oil Pressure bcos if the oil pressure dips, then the Engine might get seize.
Should you require Spare Parts for Zetor 5911, we can offer the same at very attractive prices.
Thanks and regards
Rajiv Ahuja
rajiv_ahuja@yahoo.com
Thanks and regards
Rajiv Ahuja
