question 8045 Crystal no brakes
okjoe
Joe
I started tractor after sitting for winter and found that brakes are not working at all. Pedal goes down with very little resistance.
Brakes worked fine before winter. I dont know where to start to find out what the problem is.
Did you try pumping the pedals a few times to see did it build up any pressure?
Then you may start with check the brake fluid vessel is full, then try the both slave cylinders on the backend for leaks, then try the master cylinders under the floor at the brake pedals for leaks. If any of them are leaking this would give you no pressure.
You may need to bleed the bakes if air has gotten into the system.
DIY farmer, thank you . I will try that , hopefully it will solve the problem.
