9541 Proxima Plus
adcilleo
adcilleo
Looking for help , gear shift on 9541 proxima plus is difficult and I have to really force it in to gear and the forward reverse lever is even worse. Any advice would be appreciated. Thanks.
Does the tractor try to move when you try to get it into gear? If it does you have clutch drag. If it's just tight the ball under the gear lever needs greasing.
Is your shuttle lever on the dashboard ? If it is they seize on the pivot point. Copperslip is the cure.
