gearbox disasambly
bjarne_iversen
Bjarne
Hi friends,
My brother has broken his drive clutcpiniona and now we are wondering is it possible to pull it out forward after we take the figure 8 flange of,its a standard 10+2 box in a 7045.
You mean you broke the input shaft of the transmission ?
Yes you can take both shafts out very easy when you take off the figure 8 bearing holder.
If you need to go deeper than that (past the 540/1000rpm PTO) you need to take some gears from the top, and one from the bottom. But replacing an input shaft is simple and straightforward.
