An interesting project and comments to date. I have never put a turbo on a diesel tractor engine but the characteristics of various turbos are tailor made to suit the application. The wide variation of custom turbine and compressor blades is a world of graphs and data.
Because a tractor is running more of less at a steady rev state when working ( which is generally when you want more power) then many of the considerations used when matching to turbo to a car engine can be ignored..
For cars reducing Turbo lag during acceleration from low revs to peak output required a set up with quick turbo spin up.
Hence a smaller exhaust gas turbine entry port to give good gas speed at lower revs. This can also tends to provide higher back pressure at high revs, reduced efficiency and can increase heat markedly. Recent developments in Turbo technology has seen variable port tubos becoming available.
I think the tractor application may benefit from use of a turbo which allows good exhaust flow with more generously sized exhaust gas port to the turbine. The aim is to get boost at the say 1800 - 2200 rev range and keep it free breathing as possible.
I agree with the suggestion of a turbo from a similar sized and output industrial diesel engine as generally they are designed to run at a fairly constant load / rev range. ( acceleration and low rev boost are not a design feature that compromise is allowed for.)
Any mismatch in turbo to application may show up with greater heating so a bit of care and getting experience of others is well worth while.
Car turbos are much more common and no doubt a practical choice for that reason. If a bit of small budget fun is the aim then a car turbo as suggested make a lot of practical sense, particularly if the boost level is kept low.
Water cooled turbo bearings
help look after the oil for the engine and reduce the formation of ash. Desirable but you can probably get away with a turbo without that provision if the tractor is not worked hard for longer periods. Definitely a good oil supply for the bearing is needed as well as a large diameter free flowing direct oil return to the sump. The oil out of the bearing needs space to flow away as it will be foam.
Some wind down oiling system for the turbo bearing is particularly important is you use a smaller turbo as the revs will be very high. If the motor stalls under heavy load the gas flow will be very high and the turbo will be screaming in the revs. if oil supply just stops at this condition with a motor stall,them you will cook the turbo bearings.
A turbo timer is a waste of time under these conditions and is messy to fit to a diesel tractor such as a
Zetor . A post oiler provides oil flow after the oil pump ceases to supply .
Various types can be found on trucks. Some extra reservoir controlled by ball valves to allow oil to the turbo immediately on start up but gather a quantity of oil and continue to release it to the turbo bearing when the oil supply pressure drops.
Having a chat to a truck or diesel turbo specialist may provide a few useful hints as to what choices you would be best to follow.
