How to unmount the hydraulic steering
P
Patrick
Guest
Hello,
I want to unmount the power steering from my Zetor 6711 and want to fix it on my 5911 with frontloader.
Now I have a problem to unmount the power-steering zylinder from the chassis. How can I take it off? I took off the nut but was not able to take out the ball joint.
Thanks for your help .
Regards Patrick
I think you need a special tool , over here it is called a "pulley puller", a threaded pin with a nut on it, on this nut you can attach two or three arms with hooks that are placed behind the pulley. When you turn the pin, the hooks pull off the pulley.
I am not sure how this is mounted, but i think it's a conical pin.
