Not many people have noticed, but there was something interesting on Zetors Agritechnica stand: a Forterra 150 with a 50kmh (40kmh eco) transmission.
In the cab, you can see that the 5 speed gearshift pattern is different, its like a car: that means it also has an overdrive, like a car. If they made the overdrive so that there is no overlap between 4th gear 3rd powershift, and 5th gear 1st powershift, it would mean 40kmh at 1800rpm without increasing the takeoff speed in high range. (5th gear low range is only used for fast headland speed, so the overlap between 4th gear low range and 1st gear high range is still enough)
The cab is also put up higher above the rear axle. For tje Forterra HD this is enough, but on the Crystal we might need a bit more to get a view over that big hood.
They havent adressed the door gas strut yet. But overall, the changes on this Forterra impress me better than the changes on pininfarina design... The changes on this Forterra are noticed after working with it, and the Pininfarina changes only count on exhibitions...
