- Jul 5, 2003
- 3,975
- Location
- Laag Zuthem
- Renze
1967 3011
I have been thinking: I have been a firm believer of DSG technology because it needs only dual clutches (and two directional clutches) that cause drag loss, instead of 11 for an 18 speed full powershift.
However, VW DSG transmissions dont quite have a good name after doing 200.000km... When clutch packs wear, it starts to shift rough. People choose a conventional automatic for luxury or a manual transmission for reliability and lowest cost of ownership... Deeres DirectDrive, i hear bad rumor about their practical use (shift speed adaption on hills in particular, it stalls because it cant downshift fast enough when backing a trailer up the silage heap) so the old powershift transmission is still the most reliable.
So, heres my idea: We use the Zetor three speed powershift module, and hang a single clutch pack besides it: the 3 speed powershift will shift stages 1, 2 and 3, then the single clutch pack will shift stage 4: Then the shift module behind the 3 stage powershift changes range, and the parallel stage 4 clutch is released and the lowest step of the powershift engages again: then again the 3 stage module can make 3 shifts, stage 5, 6 and 7.
With the Forterra ratios of 0.865 per powershift step, this 7 speed powershift would have the same ratio spread as the MF Dyna6 transmission. So, lets start at 50kmh, it will run 21kmh in 1st powershift, range 4. The 3rd range will start at the same speed 21kmh (one overlapping gear) and 1st powershift, range 3 will give us 8.8 kmh. Then we have a tillage range 2, which spans the tillage working speeds of 4.25 to 11 kmh. The overlap will be bigger between range 2 and 3 because you dont want to shift ranges with the plough in the ground, the tractor will come to a standstill and will not be able to take off in 3rd range under full load.. Therefor we need to get the tillage range up to 11kmh, if the plough pulls so easy that it can pull it faster than 11kmh, the draft requirement of the particular implement is low enough to take off in 3rd range at 8.8kmh with the implement in the ground..
Then we have a PTO tillage range 1, from 1.8 to 4.5 kmh, also with one overlapping gear.
this would be a development path with a failsafe included: if the DSG part would not function with claw clutches, it could be replaced by disk clutches down the road. And the most important feature: It only requires "dumb" black and white shifts, just like the current 3 stage powershift unit: The ranges preselect without power, because the 4th gear is an intermediate gear which disconnects the 3 stage powershift unit for preselection of the next gear. The software could release pressure from an accumulator (piston, membrane doesnt last) to quickshift the range, while the transmission oil pump is only used to engage the other clutch pack on the 3 speed powershift unit...
Practical result is that you get a 7 speed gearbox that only shifts one clutch at a time, smooth without modulation, just simple shift logic.
It is quiet around Zetors DSG gearbox, consisting of the 3 speed powershift unit with a 4 speed DSG range behind it, e.g. creating a 12 speed gearbox which has a lot of time to preselect the ranges (required every 4th shift) when shifting straight up or down. It has little benefit when jumping up and down between step 3 and 4, then still quick range preselect changes (which seem to be difficult for Deere) are required. Als the patent they have, on a DSG shuttle shift transmission doesnt work (both shafts are occupied to make the gearbox reverse so the drive must be interrupted to change gear reversing), and their first functional prototype combines the price of multiple clutch packs with the added difficulty of shifting a range and the powershift at the same time, whilts having only the benefit of more time between range changes when you run straight through the gears, not move up and down between 3 and 4 (which one, based on what parameters should the computer decide to preselect ? There will still be a dead shifting spot in the gears) Therefor i think the 3 stage powershift with two powershift ranges behind, with an intermediate gear on a paralel shaft to allow single clutch shifts between every gear, will be worth investigating, and perhaps a lower risk development...
