Hi All,
My old 8011 was working well and lifting arms worked perfectly in June. I hitched up a small tipping trailer and used it for a few days in June. Zetror has stood since with trailer connected.
I started it yesterday and tipper worked fine on the quadrant. I tried to drop the hitch (lever in cab to free hitch lock worked) using outside quadrant lever but nothing happens hydraulically. I see the quadrant centre moving so lever is not slipping. Quadrant has full range available. Inner control changes engine note as pump works with trailer disconnected but outer does nothing. Lift arms are up and don't move.
Have I forgotten some trick or hidden lever?
P.S. I tried backing it up onto a pile of earth but no difference.
