3320 brake problem
grahammailpost1com
Larry
brake pedal goes to floor on my 3320 (recently purchased). where is the brake cylinder to add fluid? do i need to bleed the lines after adding fluid? any info would be apprecaited...thx
brake resivoir is on far side of engine compartment from where you open hood. It will be on right hand next to firewall.
Keep this filled it is also clutch reserve, for my model year anyway.
searcghthe forums and you will find a lot more info about brakes.
