I don't think there's much to adjust. It's a hydraulic clutch mechanism that uses fluid from the brake reservoir. There's a little bit of adjustment at the clutch pedal and nothing else. Oh, make sure to grease the shaft going in to the clutch itself. A zerk fitting is 'hiding' down there next to the housing. If that gets dry, the clutch will act 'funny'. Good luck!
