Not sure on the 3320, but on the UR1 series with centrifugal oil filter the filler was a screw in plug (about 1") facing up, next to the filter housing. (right front of engine ...... when seated)
i believe some models (without the centrifugal filter) had a filler/breather on the top on one of the rocker covers
The 3320 doesnt have the centrifugal oil filter, it has a washable mesh disk filter (which can be replaced by cartridge filters) so you dont fill through the centrifugal oil filter either.
The 5245 has the same engine, it had the dipstick on the left and a plastic screw cap on the right, its embedded into the side covers behind which the camshaft is.
