3320 ignition switch wiring
roadpacker
roadpacker
I replaced the switch on the 3320 and I may not have connected it correctly. I have checked fuses and they are ok, but I still have no circuits working except the starting circuit, I put the key into the switch at the"0" position and hit the starter button and it starts up like it should, but no other lights work, even the alternator "idiot" light is off and the bulb is good. I I have a shop manual that shows the switch on the wiring diagram , but the print is so small I really can't get much benefit from the diagram. Does anyone know where I can find a readable wiring diagram that shows terminal numbers and wire colors? AS stated above, I think I may have incorrectly wired the new switch. Any help will be appreciated.Thanks, Skip
see what you can do with this.
http://www.farmphoto.com/thread.aspx?mid=1041539
taken from old thread
This is an old thread and when I revisited it to refer back to the link for the wiring diagram it was no longer available. I would really appreciate it if someone could re- post the link to the diagram. Thanks Skip
