3320 slave cylinder?
jnscott62799
JAYS
one more on a 3320. after using tractor a little while clutch pedal goes to floor, I can pump up like brakes and it works fine for a bit then does same thing. Slave cylinder on side of trans? or internal problems? Thanks
You have got a leak either in the slave or master cylinders. the master is in under the dash, the slave is down at the clutch control arm.
