3320 will not go into gear
jadeeller
Jade Eller
Ive got a 3320 that just grinds when you try and put in gear. Ive replaced slave and master. Still no luck. Any advice before I split it?
Did you try pumping the clutch pedal a few times to be sure all the air is out of the system.
Can you tell me where it is on a 5245 of how to bleed air out, I am having the same issue as the guy with the 3320!
