hy fellows, my problem is the brakes on a 4341,i can pump them three times and i have brake peddle,but the brakes are still not good. could one of the master cylenders cause this.i see that both cylenders plumbed together. any help,thanks
renze,thanks for your reply.anwser to your 1st quston,i have toped off my oil reservor,and it dosnt seem to be losing any fluid.also my emergency brake dosnt work.the clutch is working fine.I first noticed the brakes getting soft and then they quit completly. after pumping them three time the brake peddle is hard but the brakes are less than half .compaired to beforany more info will be a big help. thanks again
maybe you have air in the system. Did you bleed it at the bleed screw at the slave cylinders ?
On a disk brake tractor, it shoudl be easy to find. One person has to pump the pedal and the other has to open and close the bleed valve
