4712 brakes
aland
Ireland
AlanD
Zetor 5211
Replacing a master cylinder on a 4712 and the feed pipe from the Brake fluid resevoir broke.
Can only find a feed pipe for the 8011 ur2 series online.
Will this fit?
Alan.
i did the same , one of the nuts on one of the master cylinders was siezed to the pipe so twisted the pipe undoing it , 8011 master cylinders look to be the same so ive bought an 8011 pipe, not got round to fitting it yet, i reckon the reservoir end will need modifiing.at the least careful bending or maybe just end up chopping it and joining to the reservoir with a longer bit of rubber pipe, but the bottom end , teed onto the 2 master cylinders should fit.
Thanks for your reply.
Think I'll have to do the same.As long as the feed pipes line up with both master cylinders it shouldn't be a problem.
Fingers crossed
Got the genuine part eventually . Link below.
http://www.eshop-rychle.cz/ceskenaradi/eshop/2-1-ZETOR-DILY-Spare-parts/134-2-Brzdy-Zetor-Brakes/5/8085-Trubka-od-nadrzky-Zetor-UR1
