4911 PTO Engagement
quinny
Quinny
I am finding it impossible to engage the PTO at 1000 rpm. I have no problem engaing it at 540 rpm. Any idea out there as to why this is happening ?.
Also i was wondering can i attach a second hydraulic /tipping pipe as there seems to be a second outlet from the the hydraulic pump under the seat ?
Connect up a spool valve and you can have as manu outlets as you like.
Thanks for that Tomz,
Any ideas as to the problem engaging the 1000 rpm PTO ?
I assume yours has only one pipe connected to the double acting spool valve (making it possible to only use it single acting)
My 3011 also has one outlet, and i need to install a second. The valve block has the feature, but it has no connection. I need it sometimes for clamps etcetera.
Zetor only built 1 type of spool valves in these tractors, which is double acting. I think you'd be where you want to be, if you plumb a piece of pipe and a quick coupler to that outlet. :)
