[quotepost=2]
Yes, you stuff a piece of wood under the cab so it rests on the rear end, then undo the cab rubber bolt and then twist the axle portal down so it releases away from the cab mount, then you pull it out. .....Sorry for being so dumb - looked and looked this evening and I cannot see where you could posibly get a piece of wood under there to support anything--trying to sort out as many details as possible since I will be having to hire someone to come
help me with this project-need to understand and know as much as I can so every hour of work will pay off--right side with the
hydraulic levers really seems to be a challenge. Noone around here has ever even heard of a
Zetor much less know anything about them..
