bought an old tractor that is missing the fuel lift and primer pump, it has an electric pump fitted and does work for starting the tractor, should i put it back to oem, the manual doesn't indicate how the fuel lines should be connected, anyone know how the lines should be connected ?
The hand primer goes onto the hole on the right, a pipe coming from the tank goes on the bottom hole on the left and a pipe going to the left side of the filter goes on the top hole on the left side.
the fuel feed line is the one with the loop @ where the original fuel primer was, is the fuel injection pump a bosch unit, also what is the model # ?
i have read the primers are known to be a problem with leakage so i intend to remove the lift pump and fabricate a block off plate, then move my feed line directly to the banjo fitting behind the pump, thoughts ?
the hose and routing was temporary, was waiting on fuel filters to arrive, the filters are now installed and the hoses corrected, trying to keep as original as possible but use an electric fuel pump.
