I have a hydraulic leak on my 5211 under the cab
it leaks out the banjo bolt on the raise side Do the copper washers go bad as I cannot find any other problem with it
its worth looking at.
I would look first at the hose that runs to the external lift ram. Ours rubbed bare and blew when i hit a pothole on a dirt road with a 3pt bucket full of wet soil i dug from a ditch.
thanks for reply. Fixed my problem.The copper washers on the banjo bolt were pitted and leaked under pressure. Replaced with new ones and that took care of the leak. I had tried to re-tighten them but they still leaked. $2 washers were a cheap fix
