While replacing the water pump, hoses, thermostat and housing, temp sending unit and
fuel line that feeds the injectors on my 5211....I removed the radiator, hoses and all the usual parts....in addition to the exhaust manifold etc.
It took several days to acquire all the parts and while putting everything back together...I had a "mind burp" and my old memory slipped a cog or two....and wasn't sure what to do with 3 of the wires.
The replacement thermostat housing is of a different material than the one I removed and the sending unit is on top instead of the bottom of the housing.
I'm fairly sure one of the blade type connections goes to the temp sending unit....and there is a wire with a "eyelet" type connector that seems to come from a small terminal on the alternator.....not sure what it's purpose is.
Anyway....my temp gauge isn't working now....it had been working fine when the pump crashed.
I'm assuming the sending unit should be grounded (since the thermostat housing is supported by rubber hoses and not touching metal)
I'm fairly certain the 3rd wire I mentioned goes to something in the headlamp/horn area.
All of this leads to one dumb question.....Does the sending unit/thermostat housing unit need to be grounded and could the eyelet type wire be that ground?
If you spent the time to read all of this....I appreciate your interest and thanks in advance for any
help.
Happy Trails from the Texas Hills
