Then i ordered the wrong shoes for the 5511 as well.. nevermind, they DO fit the 5718.. I assumed them to be the same on all four cylinders because the differentials are pretty much the same for decades...Hi your supplier is correct
stuck piston in the slave cylinder. The cylinder looks fairly new and not corroded but one piston is stuck fast.
Thanks for the info. I fitted a new slave cylinder and portals are back on but will consider this in future. I bled the brakes but when i press the pedals independantly they both go to the stop and shoes just make contact however if i press both pedals together the brakes are good with pedals only going about 1/2 way down. Anyone seen this before?
I did notice however that there are no return springs for the pedals but they do come back fully without these.
I cant see why this would cause my problem but will order springs along with seal kits for cylinder and equalizer.
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
