6011 pto problem
fluffy57
fluffy
My pto is hard to get it i am having to play around with hand clutch its making alot of crateing sounds when trying can anyone help please
check if it actually releases if you pull the lever. It can be out of adjustment or the cable is stretched. Also the buttress caps may be broken, or the levers itself. The clutch isnt releasing far enough, track this problem down from the lever towards the clutch plate.
