60111 rear brake problem
fluffy57
fluffy
Hi I have a 6011 with rear brake problem can anyone guild me on process of stripping them down .I have been losing fluid but can not find any leaks so another member thought the fluid is going into rear axle . So thought is now maybe wheel cylinders rubbers gone hence need to stip down so can anyone help please .
brakes are in the back axle , either side of the centre bit, wheel of , engine crane or similar to take the weight of the half axle, unbolt the half axle slide it off , brakes should be visible.
try the thread up the top ...drum brake basics
