Trying to maintain a 7211 tractor that was out of action for more than 7 years I am facing a strange issue.
The hydraulic lift can not keep upper possition all the times.
When the operator moves his hand from the lever then hudraulic cylinder retracts.
This could be 2 things.
1st Piston seals damaged and/or
2nd main Valve piston under heavy wear or a safety valve is leaking.
I have made a proper repair to the lifting cylinder but the system behaves the same way. In the operators manual there are not enough information for a manifold inspection.
Are there any documents for the 7211 hydraulic system available to any forum member?
