7245 Brake System
valley7245
Valley7245
Zetor 7245
What is the diameter of the "Brake System Bleeding Hose", part number 6911-8551. I know I can get a piece of clear plastic hose, if I only knew the diameter.
Thanks in advance, Valley 7245.
Same size as a car one, Around 4-5mm I/D. dont get one much shorter than 500 mm unless you have a helper to hold the can!
