Hi, nice forum you got here, I have already found few usefull sulotions to other problems with my 7745 here.
Today I started it, as normal with clutch down and in gear. Engine running fine and no bad sounds. I put it in free, let it run for a few minutes. Then cluched again to reverce, and there was no propulsion. Now I was unable to press down the pedal again, not with normal preasure, so obvious I did not try force it. However it still makes its usuall cranky sounds if I try shifting gears.
I took a peek inside the inspection hatch for the clutch, but I did not turn the clutch around, because it was -20 C, windy and I was a few miles away from my workshop and already freezing my fingers to death. But I think there might be something wrong with the "arms" that keep the clutch plates in place.
So I was wondering, any opinions on what broke ?
Will it be safe to pull it to my garage with another tractor, or should I fix it where it stands ?
Have anyone experience something like a clutch freezing ?
In advance thanks, and sorry for my poor english
