bleed brakes on 7211
hi you need to be two to do dis
when you stand behind the tractor you will see brake lines going inn at the top off portals bled valve is at the same plase not
visibil
you ned a 9mm long soket 1/4inc sett is best
fill tank vidt brake fluid ,split pedals start by pumping presure
wile holding pedal open valve to lett out air close vale relese pedal
repite untile no air coms out remeber to check tank so you dont pull air into the brake system again repet on the otter side,hope
thise helps you
I am just doing the same job on my 6211 today! I found the valve on the right hand side but there doesn't seem to be one on the left hand side?? Can anyone help ??
hi it might be broken off ,it sudh be rigt nekst to the brakepipe iff it was in front off the pipe on the right hand side it might be onthe reare off pipe on left side ..
