- Jul 4, 2010
- 90
- grumpy
hi all, could someone point in the direction of any bleed valves on my 6711?
i have a handbook and an operators manual but in neither is it mentioned.
had the tractor for a year or so now and the brakes worked, (well one did ) but this week needed to tow heavy trailer down a steep hill so thought i'd have a tinker. i found that the two pedals were seized on the shaft together, so freed them off and greased up.
left pedal works fine , right goes to floor. topped up fluid and it improved a bit but cannot find bleed valves. are they hidden away inside somewhere?
under normal slow moving load, brakes work (ish) but under heavy load, pedal jumps and judders then drops to floor! panic!
any clues?
cheers
any clues?
cheers
