cab heat
roadking
Steve Kmyta
I have a 5245 zetor with no cab ,I bought a used cab and installed it on my tractor.....big job!
My question is where do I connect my cab heater hoses for best results????
One goes on the back of watermanifold. you might have to buy an original outlet that screws into the manifold. the other one goes on a fipe that comes from the waterpump if i remember correctly. you might have to buy the pipe accessories too.
Yes, the feed hose is screwed directly into the water pump. Its plugged with an inner hex head screw on cabless tractors.
thanks gentlemen,
found both plugs .... the water manifold I figured was 1 but I wasn't sure of the water pump fitting after giving the front of the engine a good bath there it was!
thanks again for your help
Regards
Steve
