Hello.
Our 5211 is leaking from the fuel lines and would like to know what type of fuel lines and size to purchase. The present lines are rubber with a outer cloth fiber, but getting old, so need to change them out. Thanks for any help .
best you can get is standard Gates rubber with steel wire cloth covering. Most tractor dealers have it. I'm not sure about the size but it's all pretty standard.
dont forget the line that goes behind the fuel pump. its often overlooked and therefor a cause of many leaks.
