I just think it's worth mentioning that I really like the original lift pump, but I use the tractor almost all the time in different elevations and inclinations terrain, so with the lower
fuel tank it just couldn't handle the job.
I bought just a regular, generic Chinese pump of branch "Euro - for diesel". You just cannot trust in any information given by its sellers or datasheets, but it's the only thing available in Brazil. But I have to confess I have a satisfactory surprise regarding both its reliability and strenght - even being installed after the fuel filter (midway between filter and engine pump) it supplies more than enough fuel to the 4-cylinders and return, usually working for up to three hours in low-gear.
Prior to that, I had tried another model similar to the gasoline vehicles, with the pump working submerged in diesel, inside fuel tank, but that one have lasted for less than three months - maybe it was too much work to push fuel thru the filter.
This current "Euro" one is working for more than 4 years now, with no problems at all.
Edit: it's one like this, used in mid-weight diesel trucks and vans down here in Brazil.
Allegedly, "4,0 BAR pressure and 100L/Hour".
Encontre mais produtos no Mercado Livre
produto.mercadolivre.com.br
