OK . Also have 260 SLi Trac Lift on 120. found it to be very good, visibility a bit of an issue (old type cab) but not to tall so can cope, a 1 tonne rear weight is a must for serious loader work.
DPF been a problem though, the only real issue I have with it.
The only good DPF is the DPF that sits on your attic untill you ever decide to trade the tractor... Zetor should look at FPT, Sisu, MTU/Mercedes and JCB, not at the americans with their urea anxiety...Dpf was causing problems on mine to. so dealer put in a dummy filter no more dpf problems
ive heard the same. its a shame since the trac lift was a good loader
But quicke wich they now will deliver is better
Ploughing in a few days, will play about with settings.
just thought are not Trac Lift loaders fitted to Fendt.
Not entirely, Fendt loaders also have the patented Traclift concept of a single weld seam profile rolled from plate..no not trac lift loaders. but the trac lift factory makes loaders for fendt With fendt design and specs.
