S
Saskatchewan
Guest
I recently noticed that my injector return lines - flexible cloth-covered lines running from the back of the injector pump to #1, 2,3 and ending at #4 injector - are leaking through the cloth covering material. The leak is just seepage - enough to cover the LH side of the engine, but I specualte that it will get worse.
The hose lines have metal crimped ends which attached to the top and front side of each injector. There does not appear to be any place to attach a wrench to remove them.
Can they be replace and how?
