Ha Markku,
I brought the heads of the former engine of your 7745 to the overhaul shop i travel past everyday on road to work.
There were 3 or 4 black pits in the valve seats, so they polished them with polishing paste, 4 euro per valve.
On the old heads there were black pits all over, probably a 40 per valve seat.
I have de-carbonated the pistons with DOT4 brake fluid, this works really well on carbon and tar, it just dissolves it.
Anyways, maybe i need to run the engine hot first, to burn out all the brake fluid and WD40 used when mounting it.
This tractor never ran as it should, all the 6 years we have it now...
I will test the
fuel nozzles and injection pump by taking the fuel nozzles out and mount them to spray next to the engine, where i can see them and see how they perform. If anything is wrong, it must be the fuel pump because the injectors were tested last spring.
I can also run it through a
compression test. That may show if the piston rings are bad, because the heads are 100% now..
Markku, the difference between 3 and 4 cylinder heads is only the bolt pattern of the intake manifold... i had to weld new flanges to the intake manifold, under another angle. it uses the same gaskets and flanges, but under a different angle, because the 4 cyl. have a aluminium cast manifold and the 3 cyl has one made of pressed sheetmetal.
Anyways, the heads are 100% so it should be either the piston rings or the injection (pump)
