fuses and fuel gauge
micd
mic-d
the 5245 has blown a fuse or 2. Can someone tell me the rundown of the fuse map.
Also the fuel gauge only reads full (not stuck). Someone filled it to the brim the other day, something we don;t normally do, is it possible the float has jammed, or could it be electrical?. how to fix it?
Cheers
Michael
I am having this same issue on a 7245. Just reads full all the time. What shall i look for?
The easiest way to fix this is to open off the float and pull it out of the tank, and work the float up and down in your hand, you probably find that you will need to buy a new gauge float. The little wires in the cap are worn and not working right.
Unless someone was fiddling with the wires and the connections are on the wrong colours.
