question How to repair the injection pump - Zetor Proxima 120 Power
Ionut
Romania
Zetor proxima power 120 hp an 2015
Engine Zetor Z1406
Bună ziua,
am un Zetor Proxima Power 120CP din 2015.
Vreau să repar pompa de injecție și nu știu cum să o configurez.
@Ionut
English please... and read the pm you become after your registration.
You can use Google translator if you do not speak or write so good in English.
Thanks for your understanding.
Sory
I used a google translate but the page was automatically translated into my language.
I have a Zetor Proxima Power 120 hp .
The injection pump must be changed and i don't know how to mount it .
Timing pukp and timing engine tco.
Hello,
ok, settings for mounting a new or repaired Zetor Proxima Power 120 injection pump. I can give you the needed informations after my vacation next week If no one others can help you.
Inner this time, it will be nice if you upload one ore more photos from your Zetor Proxima... ;)
Put No.1 cylinder at TDC on compression stroke. (Valves on No.4 rocking) put pin in flywheel hole.
Take cap off side of pump and remove spring. Put pin back in and turn pump to find hole to lock pump. Fit to engine and torque up nut on front.
Thank you very much.
I found a video of the pump where it gets stuck.
The engine is pulled on piston 1 in compression . The valves are closed and the piston is up.
I'll check the flywheel for that stuck hole.
Is piston 1 marked from the front of the radiator or from the back of the flywheel?
