I have replaced the 20 liter pump by a 32 liter pump on my 5245. On the 5245 the 32 liter pump was optional.
I dont know the internal diameter of the oil lines and valves inside the 7011 but for 32 liter, it should be 12mm.
I am not sure if a 20 liter pump is still available but the 32 liter pump slips in easily into the same place as the 20 liter pump.
In Holland, the dealers no longer sell the 70 l/minute oil pump in the Forterra because the return line is causing too much backpressure and causes to wear out the pump even when it isnt used (because it has to push 70 l to small valve blocks)
with 60l/minute there is no problem.
