Hello.
Hi recently having fitted a recon inj pump to my 12045 i now need to spill time this .How do I do this ? Also i need to check the valve clearance and need the inlet / exhaust settings and a simple way of doing this.
Liam.
[quotepost=1]
Liam.
The injection pump, i believe, is connected with 3 bolts in slot holes. you can untighten them and turn the pump (with running engine at 1000 rpm) and listen to the combustion noise. The smoothest noise gives the best overall performance.
Early timing gives hotter combustion and more power ?? and late injection gives better fuel efficiency and colder combustion ??? I'm not sure what setting causes which effect though...
Thanks for the information but I am more concerned with setting up the injector pump timing correctly. My understanding of this procedure is to locate top dead center on number one piston and having the pump fully primed move it on the slots to obtain fuel movement in number one port of the inj pump. Is this the correct way of doing this ?Also I need the correct inlet /exhaust valve settings . Any help is appreciated.
Liam.
