There is no one-size-fits-all solution...
It could be a lot of things (also combined):
- the 5545 has the tank at the level of the injection pump, here diesel does not flow back to the tank as quickly. The 5011 has the tank lower down, if the hand pump or the valve in the diesel pump or the hoses on the suction side to the tank or the pre-filter are leaking, air can get in and the diesel flows back to the tank, then the only thing that helps is to seal everything correctly or pre-pumping.
compression too low (wear, broken/broken piston rings, wear on the cylinder liner, incorrect head gaskets, poorly adjusted and/or worn valves, ...)
- starter speed too low (gearbox starters turn faster = easier start, more compression a little faster)
- defective injection nozzles (poor
fuel atomization, dripping and/or clogged nozzles, incorrect spray pressure, ...)
- defective pump elements (pressure too low, leaking)
- problems in the engine oil lubrication circuit (it takes too long to build up the lubrication pressure, consequently poorer compression values)
- air filter completely dirty
... and a lot more.
Without more information and photos of the condition of the tractor, it really isn't possible to say much more precisely.
