Hello I'm new here. I've bought a Zetor 6245 with a brake failure. The brake cylinder on the left side is leaking. I think I have to open the brakes house and shift the cylinder and the brake shoes. Is that difficult? The parts I think I have to remove looks very heavy. Is there anything I have to be careful with? Does anyone have a picture of the brake system? I ordered the workdshop manual but it will need 3 weeks to come. Thanks for your help
Sren
message sent. check your messages. and yes you will need some heavy lifting gear. after removing rear wheel, remove housing which is heavy (use engine hoist or similar) all should be apparent.
Now the pipe on the left side is broken and I've to change it. Is there anyone who can tell me how to do? the skrew on the other side of the pipe sit also very hard. Can I open it with just using a lot of power, or do I destroy only more parts? Do I have to take away the cabin? Thanks a lot for help.
