- Joined
- Feb 13, 2024
- Messages
- 136
- Location
- Windsor Vermont
- First name
- Robert
After changing the old Gearbox/Hydraulic oil to the new Gearbox/Hydraulic oil
(Ultra1Plus SAE 75W-90 Synthetic Gear Oil, API GL-4)
it is leaking from a bottom rear right side hole.
I did over fill a little, which other post said was OK to do when operating on side hills.
When I received the Zetor 3340 back February 2024, there was no leaking with the old Gearbox/Hydraulic oil,
which was just touching the bottom of the dipstick (very low).
The oil leaking from this back hole looks to be from where the brake compartment is.
This oil leaking seems to increase more when driving down hill,
then when Zetor 3340 is diving up hill.
Not sure why this seem to be happening yet, maybe oil is collecting in the brake compartment
and exit out of the hole more when going down hill.
Could this be a seal has failed on the right side and if so, what is the part number for it ?
Click on picture to see more:
